AAEON AEC-6910 BOXER S PC
Myydään passiivijäähytteinen pienikokoinen pc.myydään ilman kovalevyä.
Speksit:
CPU Intel 1.6GHz Celeron M Processor
System Memory DDR SDRAM DIMM x 1, Max. 1 GB (tällä hetkellä sisällä taisi olla 500mb)
Expansion PCI x 1 (optional 2), PCMCIA slot x 2
VGA / Keyboard / Mouse DB-15 VGA Connector, PS/2 Keyboard & Mouse
Ethernet 10/100Base-TX RJ-45 connector x 1
SSD Type II CompactFlash™ slot x 1
Hard Disk Storage 2.5" Slim Hard Disk Drive Bay
Serial Port RS-232 x 4
Audio Mic-in / Line-in / Line-out , by extension cable
USB USB 2.0 port x 4
Parallel Port Print port x 1
System Control Power on / off switch x 1, Reset button x 1
LED Indicator Power LED x 1, Hard Disk Drive active LED x 1
Watchdog Timer Generates a time-out system reset, setting via software
Power Supply 1. DC Input -- Internal DC-DC Converter(Default)
Input voltage: 9V DC ~ 30V DC
Mechanical and Environmental
Construction Rugged Aluminum Alloy chassis
Color Mustard
Mounting Wall-mount
Dimension 214mm (W) x 94.75mm (H) x 237.8mm (D) - 1 PCI
214mm (W) x 117.5mm (H) x 237.8mm (D) - 2 PCI
Carton Dimension 336mm x 294mm x 260mm
Net Weight 5.63kg - 1 PCI
6.21kg - 2 PCI
Operation Temperature 5°F ~ 131°F (-15°C ~ 55°C)(P-M 1.6GHz,CFD)
5°F ~ 122°F (-15°C ~ 50°C)( P-M 1.6GHz,Automotive HDD)
5°F ~ 113°F (-15°C ~ 45°C)( P-M 1.6GHz,Normal HDD)
Operation Humidity 5~95%@40°C, non-condensing
Vibration 5 grms / 5 ~ 500Hz / random operation(CFD)
1 grms / 5 ~ 500Hz / random operation(Internal Hard Disk Drive active Module)
Shock 50 g peak acceleration(11 msec. duration)(CFD)
20 g peak acceleration(11 msec. duration) (HDD Module)
EMC CE/FCC class B
(https://puu.sh/xgAfX/e3616f15ee.jpg)
(https://puu.sh/xgAey/193b583c8b.jpg)
Katso koko ilmoitus (http://www.cnc-tekniikka.com/CNC-forum1/index.php?action=classifieds;sa=view;id=1093)
